Doing a very small job with very conservative speeds and feeds and one of the bolts from the spindle mount apparently sheared off inside the threads and shot out at me, and one bolt is completely missing.
That sucks the machine is down. The missing bolt came out at some point and no one noticed a random allen bolt on the bed or floor?? I’m glad it is not as bad. We can get bolts on Monday.
The repairs to the Swift were completed tonight. I believe we got the new spindle trammed to within .001 in. I surfaced the spoilboard and everything looks good so far. If no complaints are found, I will likely replace the spoilboard Friday night.
Thanks to @morrism14 for a tremendous helping hand, and @JoeN for having the correct tool to tram the CNC. Seriously, what doesn’t Joe have.
We also believe we found some underlying issues that could have helped cause this problem. The new repairs should avoid that issue.
One thing I will say - I think the small cnc could benefit from a tram as well. When I did leveling on it with a leveling bit, I noticed that the surface is not completely flat - and has very slightly angled grooves along the surface. I thought it was my bit, so I bought a brand new one and it does the same thing. I’m not sure how big a hassle it is - but I am totally willing to learn how and do it if that would take the load off all the stuff you guys already do.
I can swing that - I’m already scheduled up there for some stuff tomorrow. Do we have spoilboard stock up at the space? And does it need to be planed to a particular thickness or is it just a cutting job?
Oh - and I’m guessing those pieces also have countersunk bolts holding them down… I can’t remember? If so, do we have a model for the pieces with those laid out?
There is some MDF (some quite thick) behind the machine shop cabinet that is for Asmbly projects that might work well for pieces for the small CNC apoilboard.
