We continue to live and learn new things in the metal shop. And we’ve recently learned that our primary saws, the horizontal and vertical bandsaws and the cold saw, will not cut stainless steel at all, and you will destroy the blade if you try. We hadn’t encountered this before; indeed, the vertical bandsaw and cold saw list appropriate speeds for cutting stainless steel. These were based off charts and calculations, not experience; experience has trumped these.
We’ll update the charts and add appropriate signs, but from now on, do not attempt to cut stainless steel on either bandsaw or the cold saw. (And attempt is the right word, because you’ll get little more than a scratch on your piece if you try.)
So how can you cut stainless steel if you need to? The thing I tried that worked best was actually a cutting wheel on an angle grinder. This in turns suggests that our abrasive chop saw would work as well, since it’s basically a huge cutting wheel. This tool has been made more accessible, but it is a strictly “at your own risk” tool that we haven’t covered in the metal shop safety classes. It’s vise is not at all as secure as I would like, it will generate a ton of sparks and heat while cutting, and the “blade” is basically a giant Dremel wheel, which will sometimes disintegrate just like its smaller cousin, much less often but far more violently due to its size. (I have experienced this personally, which was not fun. I may mount the remnants of the wheel somewhere as a warning.) Face shields are required when using this tool, and be mindful of where people are around you.
We will add a new option soon. We purchased a third-generation Evolution metal chop saw a few months ago; we just hadn’t figured out where to set it up. We will sort that out, and we will purchase appropriate blades for cutting aluminum, regular steel, and stainless steel. This will also be an “at your own risk” tool; the blades are safer, and the vise is supposed to be vastly improved over its predecessors, but it will still throw sparks and small cutoff pieces around. Face shields will be required for it as well.
If you have any uncertainty about using these smaller chop saws, please talk to a steward for assistance.
