Hello, I am working on the Dorian laser cutter getting a transfer failed message. It says there was a problem sending dad a to the laser. The machine may be busy or paused . I have started over twice. Do any of you have a clue how to fix this? Thank you Gian
I’ve seen it do this from time to time when getting stuck after having an error. I’ve been able to resolve it by hitting the reset button on the machine control panel.
Thanks, I’ll try that
This will happen if you pause the laser, then attemp t to send the file again. In such cases you need to hit the escape button on the laser. Then you can send a file.
