6/19/2026 20:51:28 - Lasers - Tarkin
Problem Type: Equipment
Workspace: Lasers
Asset: Tarkin
Summary: Cutting seems a bit more difficult
Additional Info: The user before me told me that he was having issues cutting through 1/4 in plywood. I had similar issues cutting acrylic..I had to slow the tool path way down to get through
hello has anyone had a chance to check on this?
Partially fixed.
There’s still some minor ghosting, but most functionality has been restored. Check out the Tarkin Yellow Tag 6/20/26 thread for more detail.
Thank you for looking into this Nick,
Do we have a plan to get the small machines up and running.
I mostly use Tarkin for cutting thin acrylic and some fine etching. I noticed the small lasers have been down the last few times I’ve been in.
Thanks,
Gus
Hello, I just used Tarkin again today. Its working well, I dont see ghosting anymore however the laser power seems to still be a bit weak. Normally 100/100 P/S will blast through my 1/32 acrylic sheets but it was struggling. I slowed it down to 90 and it worked good enough.
Thanks for making the adjustments.
