10/13/25 08:03PM 3D Printing - Prusa XL
Issue type: Cleaning Problem
Area: 3D Printing
Equipment: Prusa XL
Summary: Glue stick all over build plate
Additional Info: Someone put a glue stick or other material on the plate. They didn’t even bother cleaning it off.
Absolutely covered in whatever this is.
This is after 3 rounds of scrubbing with alcohol-
Not only are glue sticks against the rules, and incredibly rude to other members of the space who have to clean up the mess- they also DO NOT HELP ADHESION. It looks like the print that was last run on this plate was stopped midway through- likely due to adhesion problems.
If you are having adhesion issues, smearing what amounts to grease on the plate will not help. You likely need to clean (actually clean) the build plate instead.
Aaaand 30 minutes after I was supposed to have started my print and left the building, it’s clean!
Thanks, Nick.
I want to reiterate that we have a no glue sticks policy at Asmbly. Please don’t leave messes for the next person to clean up.
There’s a chance this may be UV resin contamination as well after further discussion. Please be careful while using any isopropyl alcohol containers in the MPR until they’ve been double checked by a steward.
Confirmed. Someone filled one of the wash bottles with contaminated IPA.
