The 5 pin din cable fell out as I was using the Tormach probe today, luckily I had the same probe with me. Swapped it out, then webforum’d my way to adjusting concentricity, effective tip diameter, and tool height using a 1-2-3 block and the 19.998mm ring gauge.
It looks to be probing well now (under half a thou variance on x/y) and I was able to resume my part, but I wanted to mention it since there’s an upcoming Tormach class and I’m not certain I did everything properly. Hopefully!
If down the road there’s interest in using a waterproof and/or locking connector for the aux input panel, I’m interested in making and swapping the parts.
It felt crunchy inside before the threaded part totally broke off, not just a bent tip unfortunately, but it was a good way to learn quick!
