We have lots of upcoming changes in the woodshop. There is a lot of important information here so PLEASE READ.
Sanding Area changes:
The new sanding area will soon open up and new tools are coming on line. Please read this for important details on the sanding area and other Woodshop tools.
The new sanding area will include:
- Delta 31-484 Tilting Oscillating Spindle Sander
- Powermatic 31A Combination Belt / Disk Sander
- South Bend SB1097 Edge Sander
- Grizzly Downdraft Sanding Table
Not located in the sanding area, but part of the power sanding program are:
- Supermax 25-50 Drum Sander
- Powermatic WB-37 Wide Belt Sander
An Advanced Sanding Class will be offered soon. This class will cover all of the powered sanding equipment listed above.
Asmbly will provide some basic abrasive belts, disks and spindles. (Still not for the Supermax Drum). A donation QR code will be placed around the sanding areas. Please contribute if you use the sanders, especially if you burn through one. Asmbly will provide cleaning sticks so that it is easier to maintain the abrasives.
If you do NOT take the Advanced Sanding Class, only 2 of these tools will be available to you:
- Powermatic Combination Belt / Disk sander
- Grizzly Downdraft Sanding Table (still use portable dust collection attached to sander)
(We strongly recommend that you take the Advanced Sanding class if you want to use these tools. They are very different from, and far more powerful than our original benchtop combo sander and spindle sander.)
You MUST take the Advanced Sanding class to use:
- Powermatic Wide Belt Sander
- South Bend Edge sander
- Supermax Drum Sander
- Delta Tilting Oscillating Spindle Sander
We included the drum sander in the Advanced Sanding Class because it does not get covered heavily in Woodshop Safety, and people continue to destroy the conveyor belt and sandpaper.
If you are already comfortable using the drum sander, you may continue to do so. However, we strongly encourage you to take the Advanced Sanding class. Taking the Advanced Sanding class will open up a whole new world of surface preparation to you.
