Just noticed the rear door in the wood shop isn’t closing all the way on its own anymore. Not sure if this has been brought up yet but in case it hasn’t.
Thanks for this report. I shared it with the stewards group on slack.
Are you able to pull it all the way closed?
Yes it can easily be pulled closed. It is just hard to notice that it is left open partially.
It happens if the door isn’t opened all the way, if you only open it halfway it doesn’t have the oomf to close completely
Probably just needs an adjustment on the valve or whatever mechanism controls it
