Thanks for sharing here. It seems to have developed the problem mid-day today, and @BillM had only just updated the stewards channel, and I was coming over here to post. Thank you for having already done that.
As things become more clear I’ll try to keep this thread updated. I sorry your work got delayed, Also, welcome!
I believe you would have met either Bill or Jeff who I understand were both working on it.
And always ok to err on the side of lots of communication! Just a few days ago I was in to use just the wide belt sander, so I know other members will benefit so they can adjust their work plans accordingly
Yes, it stopped literally midway through sanding a board this afternoon, but Jeff got it working again. Apparently the sensor that tells the machine the air is on got jammed with dust somehow.
Unfortunately it’s still not running today. My husband turned it on and got the height measurement to work but as soon as he went to feed a board through the amber light came on. We raised a red tag for it
it was working last night. It’s an air/sensor issue . I can’t stress this enough , as with all the equipment - the sander needs to be cleaned after each use .
Not always, but most times the sander doesn’t get cleaned up after its used . In this particular instance it looked like MDF was being sanded and in volume. This resulted in a very fine dust layered outside the machine and throughout the inside - it wasn’t a gradual accumulation . This most likely lead to the issue .
I’ll look at it again today and call tech support monday as well as getting replacement sensors ordered .
I agree it frustrating , I have several pieces i needed sanded this weekend as well.
