Welder #2 down
Welder #2 is currently being repaired and may be out for the next couple weeks. If you are needing to weld in the meantime you may want to be sure to book welder #1 ahead of time. The tables in area 2 of course are still available as well as the plasma cutter, so if you do not need to use the welder please book area 2 in skedda.
Thanks for being patient:)
