Vinyl decals
Im interested in printing some vinyl decals. Would that be possible and should I bring materials?
What I need to print
2 decals about 20 in wide
Hey Zachary,
You can definitely use our vinyl cutter for stickers as a member! We do have some vinyl that is free to use in a box by the printer, but if you want a specific color you can bring your own roll. For a sticker, you will need to bring transfer tape, or apply transfer tape later. If you aren’t sure of the process and want to learn more, you can sign up for one of our vinyl cutting classes where we go over stickers, and heat transfer vinyl (htv).
Do we have a way to print on vinyl stickers cut on the cutter? For example, printing a multi-color design on white vinyl instead of cutting different colors of vinyl and trying to register them properly?
Would sublimation work?
Yes, one of the three sublimated shirts hanging in textiles was made this way!
Absolutely! You can print onto the vinyl first, then use the print+cut feature of the vinyl cutter to cut out around the design to get nice crisp edges as well.
