Vacuum pump number 1 on the CNC isn’t functioning right now. I suspect a failing switch, as the pump works with manual activation of the relay. I didn’t have time to dig into it this weekend, but the spoilboard has been replaced. Pump 2 works great while the spoilboard is fresh. As always, mind your cut depths please.
Vacuum pump 1 is back to operational. Turns out the thermal overload relay tripped. Reset the relay, and back to normal.
