I know that the metal shop safety class is required to use the metal shop. Is the TIG welding class required to start welding in the area?
Ah thank you!
There are also “checkout” classes, info on that can be found here: Private & Checkout Classes - Asmbly Makerspace
It doesn’t have to be the Tig class. You can take the Mig class if that’s all you’re doing.
If you ever need a quick reference for which classes are required to book certain tools, there’s a handy cheat sheet built into Skedda. Just click the info icon next to the tool space, and the details will pop right up!
Great reminder @Sid. I forget that option is available.
