A while back Eric showed me a thread mill for the tormach. Does anyone have a model for this to use in Fusion? Or at least the dimensions so I can make one.
I believe it is this one or similiar. Micro100
Obviously check dimensions against the physical tool when you get to the space.
I found this video helpful. I used the spreadsheet and I was able to get an acceptable thread milled the first time.
I have a 0.182" thread mill like the one at this link but it is a little too small. I need to cut a 1.5mm pitch thread so a 2.2 mm offset. I’ll have to measure the one at the space.
