Is there a backup of Tarkin’s material library?
I don’t see any library in Lightburn.
Not sure if you trued, click on view, go down the list and select livrary if is unchecked. Sometimes people close the window/folder by mistake.
I found the library had been pointed to some empty location in a Windows directory. The correct file was sitting where it should be and the library was restored once pointed to it.
I do have a theory someone clicked on “LOAD” to pull in a custom cut settings library they made for themselves on a flash drive, then removed it. I believe the way this works is “LOAD” not only brings in a different library, it saves the location LB will look for the library to that location and this will persist across reboots.
