Tarkin seems to be pausing for 5 seconds or so between each cut. I dont know if its a setting in light room or something else
Always check your layer settings, including features you do not intend to use.
When you pull up to a station and make some content on a new layer, it can and often does pull up settings a prior user has entered for that layer.
Both the Custom and Advanced tabs. Sliders set to green are easy to see, but also things like “Number of Passes” and “Kerf Offset” are just numerical entries that can be set oddly with no attention-getting green flag beside them
Under “Advanced”, there is a cut stop delay. Yours must be set to 5000
