I replaced the Laguna Swift’s Z-sensor wire with the old one and tested it. I removed the “do not use” notice. I apologize for the inconvenience.
Not sure if the white wire came off again, But on Tuesday I took the puck over to the Electronics lab and rewired and connected the white wire that was broken off. We tested it and it worked. So it should be good to go.
Thanks! The puck crimps all the wires into one contact so having a single dangling white on either end should not be a problem but it looks nasty. I appreciate your efforts to make it better.
