Once I correctly homed and zeroed(Thanks @bwatt) the Swift CNC today I found that the provided X/Y offset to re-zero the tool head at the 0,0 point for the dogs was off.
The X offset dimension was correct, however the Y offset was about 7 mm above the Y=0 point.
Just a reminder to be sure to visually confirm the zero if you are relying on the position for precision cuts based on the zero/zero point.
Steve
