Surfacing bit
I don’t have a surfacing bit for the cnc so wanted to use the one that the shop has - does anyone know information about that bit? Is it available in the tool database?
I have spetool bits and have only ever used those.
I just have a simple surfacing job to do, so would like to avoid buying a bit if possible.
Thank you!
The one in the steward’s closet is a R.I.P. Precision Tools 2.5" Slab Slayer which is used for surfacing the CNC spoilboards. This vendor has a VCarve tool database you can import too. I do not have access to the steward’s closet, but independently I own one too. When were you needing it?
I think that is stored in the white cabinet at the Big CNC.
I’ve used the 1” surfacing bit in the small CNC toolbox, with the SpeTool feeds and speeds.
Thank you! Will take a look!
Thanks Brian! I’ll need it maybe a week or so, just planning ahead!
maybe I can message here closer to the date and if you happen to be in the workshop I can ask you!
If it’s in a Monday-Thursday afternoon I’ll drive over to you at Asmbly, just tell me when.
