Hey y’all, looking at taking some of the upcoming textiles classes. Wanted to get an idea of the interplay (if there is any) between the vinyl cutter and sublimation printer.
Thanks!
Thanks!
Generally, not much overlap, other than both use the heat press. The one exception being that sublimation heat transfer vinyl does exist. But it’s very much a specialty item. I do have an example at the shop - I’ll take you a picture when I’m next there
