I’m selling my California Air Tools 1P1060S Portable Air Compressor. This oil-less compressor has a one-gallon tank and a flow rate of 1.2 CFM at 90 psi. It is quiet and compact, and would be suitable for applications which are not very demanding (and where you don’t want to wear earplugs).
Item Description:
I purchased this compressor in January of 2024. The compressor works quietly, reaching the cutoff pressure (~110psi) in 50 seconds from an empty tank. The regulator adjustment is smooth and there are no leaks or cracks. The manual drain valve will blow out some rust-colored water. (This is a normal occurrence in air compressors with steel tanks.)
Included:
The compressor, including the original air muffler and muffler straw. The original packaging and instructions are not included. Air hose not included – you will need a hose with a ¼” quick connect coupler.
Pictures:
