Was just running an engraving path (30 in/min) and heard a pop sound. I assume the fuse blew but was able to remove my stick and bit
Turns out it was the breaker. Thanks for reporting @thypical!
Thanks for confirming! It appears to happened a few weeks ago. Is there anyway to avoid this?
The breaker trip is different than the fuse issue. Cause may be related, but we aren’t sure yet. I don’t believe there was anything you did to cause it. We will update when we know more.
