Hi, I tried to use the Chuck Rotary Tool today on Dorian and ran into some setup issues and hoping someone can help. I first tried the Roller Rotary Tool but it didn’t work with my particular piece of glass due to the shape.
When I framed my engraving with the settings that are called out in the Big Rotary Syllabus, I found the height (Y axis) was way off in scale.
To recap, I had the following settings in Lightburn Rotary Setup
- Rotary Type: Chuck
- Enable Rotary: true
- Mirror Output: true
- Steps Per Rotation: 14800
- Object Diameter: 4” (outer diameter of the piece I was working on)
- Rotary Axis: Y
After trying a bunch of different settings, I was able to get something reasonably close to the desired size by setting the Steps Per Rotation to 6000 and set Mirror Output to false.
I was trying to fine tune the Steps Per Rotation using the Test button but got all kinds of weird results with that.
Any thoughts on correct settings or where I went wrong when using the Chuck Rotary Tool?
Thanks
Andrew
