Here is a photo of the Sawstop Blade Guard. One is fully installed the other is showing that it replaces the riving knife or goes in the same bracket. The gray handle has to be locked or in the down position. It is easier to install if the clear part of the blade is in the up position. If you use it, return to the shelf with the push sticks and/or miters.
