Rustic finish using sandblast
I’m working on a project involving small wooden toys made from poplar wood blocks, and I’m hoping to achieve a rustic finish. I came across a video that showed sandblasting as a potential method to get the look I’m after.
The thing is, I haven’t taken the metal shop intro course yet (I’m signed up for Thursday), so I don’t have access to the sandblasting equipment right now. I’m wondering if anyone here has experience with sandblasting wood and would be willing to help me do a small test run? I’d like to see if this technique will work for my project before I commit to the full batch.
Here is a photo of the finish I’m trying to replicate:
https:// share. zight. com/ llul7vn5. (sorry for the weird link, it wont let me post otherwise)
Any advice or offers to collaborate would be hugely appreciated.
Thanks,
Carlos
I didn’t have a chance to look at the link. The sandblaster uses aluminum oxide. I’m not sure what type of media it calls for. Here is a link to different types of media. Eastwood
Another alternative might be to use a nylon wire wheel.
I’ve gotten an effect much like that with a light-gauge crimped wire wheel in an angle grinder.
Do you think aluminum oxide will be too abrasive for the finish I’m trying to achieve? I don’t have much experience with sandblast tbh. Thanks for your response!
That might be a good solution, thanks!
Yeah I’m using a wire wheel currently but I was trying to find a faster way. Haven’t tried with nylon though, I’ll consider to see if that makes sense.
The general rule is no woodwork (saw dust) in the metal shop; I don’t know if there’s an exception for the sandblaster. Before trying this you should get approval from the shop leads.
Al Oxide is generally pretty aggressive. It depends on how many times it has been cycled. The grit we normally buy is 80 grit.
