Tarkin seems to be very low power. Wouldn’t cut 1/4” ply at 10/100. Also the speed used for frame is super high. Had to run several frames to see that it didn’t go off the target material
Danny has been in and fixed the problem. It was an upstream breaker
That’s one of those failures that I would expect to have some sort of indication about. Ideally, it not turning on at all. Maybe there should be an indicator of some sort rather than just “laser power low”.
