Replacing blade and repairing bearing. Maybe an hour or two.
New blade and damaged upper guide repaired.
Please make sure blade guides are NOT touching blade when blade is turning. Should be able to place a dollar bill between blade and guide when properly adjusted. Adjustments will be required depending on height of guard.
So if you only have $20 bills youre out of luck?
