[Resolved] Printers outlet is having power challenges - extension cord needed for use
A slight power plug challenge surfaced during the Sew Social this evening, and the outlet for both printers is currently unpowered.
If you need to use one of the printers before this post is marked as resolved, you will need to plug them in via an extension cord to another outlet - ideally one of the ones on the side of the room where the computers are. If that isn’t possible for some reason, it will need to be a plug to the right of the ironing board.
The likely culprit is a breaker switch that has gone…wobbly. More to come.
Update - the breaker switch will likely be replaced Friday evening. More to come as it happens
The breaker has been changed and the plugs are functional again.
