Hey folks, after using the resin printers you must clean up the space. This means that tools should be put back in reasonable locations and all resin residue is properly cleaned up. Please use the mini vacuum to get any little bits of resin.
This is what I found when I came in today. Tools were all over the place, and a bunch of surfaces were sticky with resin. Bits of resin were scattered around and trash like a used glove was around. Gross!
I’ve cleaned up the mess and put the brushes in the lost & found. Please do a better job of cleaning up after yourself!
