Resaw startup problems
If the resaw does not start, and you have verified the emergency stop button is disengaged, lift the foot brake all the way up. The foot brake has a shutoff switch that is activated when pressed down, and the brake does not always return to the full up position to deactivate the switch.
Is this a short term issue or just common operating procedure? If it’s the latter, it would be an excellent addition to the wiki.
