Resaw is having electrical issues. Unknown type and duration.
Grizzly Resaw part has been ordered. Once again the starter has welded itself inoperable. Should be here in 3-5 business days.
Hi Shane. Curious if the grizzly is operational again?
No. Parts in but still not operational. May be wiring issue. Investigating further.
Hi Shane @Snestle,
Any luck with the resaw?
I have a deadline in short order so I would appreciate any update.
Thanks!
Chris
Hi @chris.fry,
We’re currently troubleshooting some electrical gremlins that keep bringing the large Grizzly bandsaw offline. The 1/2” 10 TPI blade on the smaller Grizzly #2 is brand new and quite sharp; depending on the thickness of your stock it might be up to the task, as long as you take it slow. Hopefully we’ll have the resaw Grizzly back online soon but we have several brilliant minds working in it.
Hi Evan,
Thanks for the update!
Chris
I went through the wiring of the entire machine today to verify connections are correct. Machine powered up once and then refused to run again. Will have to wait until Monday to contact support.
Support verified proper voltages with me at key points. Machine powered on correctly first time, but then went back to trouble state. They are sending out an electrician.
