I got a few cuts done with red today, and then it threw a head alignment error i think, needed to be reset, ran for a bit longer, then threw the following error:
“Insufficient flow from air/gas assist device.”
Usually this comes from the water filter (ceramic now IIRC) has picked up enough crud that it doesn’t flow. It’s after the reg and if blocked the reg will still show pressure.
Don’t overpressure the reg. The pressure sensor isn’t made for high pressure and will glitch out and I believe I’ve seen it read low from being over pressure
