@EricP @JoeN During the CNC class tonight there was an issue with the Red laser. Apparently the plastic pieces that hold the tubing securely for the laser carriage came loose. Well one of them did and the other hose wasn’t attached either. I was able to get the plastic piece back into the hole that holds the tubing and also got the tubing pushed in as far as I could for a temporary fix. Just giving you the heads up to take a look at it just to make sure it doesn’t need replacing.
I’ll take a look
