I have noticed the red laser is printing very lightly in the top right hand corner near home. I believe that the honeycomb bed is just bent and or damaged and needs to be leveled or replaced. If your material is stiff and leveled to the middle you might not notice too much, but I have started moving all of my work towards the middle and doing a test run until the problem can be solved.
I’ve been having similar issues with cuts on the far right side of the bed.
I’ve needed to slow down some of my regular cuts (same stuff I’ve been cutting for more than a year) to compensate.
Wondering if focus is good as well?
Is there a process for checking the bed level?
