Other than proper scheduling of the printer(s) with Skedda, is there a protocol (or recommendation) for checking in on jobs that take 20+ hours?
thx
christopher
thx
christopher
There isn’t protocol per se. If you want you can post here in the space team that you are doing a long print so others will know and not make any unnecessary trips. Try to keep prints to a day or less out of consideration for others is all I ask but it’s understandable if you have a print here or there that runs long
Thanks Randall.
fyi, I’ve got a long print on monday (May 23). Hopefully it goes ok. I’ve blocked off ~24 hrs in Skedda for it.
@christoph_lewis Hey, I got a print running for the anniversary event and will be finished in the early AM Monday. I don’t think I’ll be in the shop before 9 am so if you could place the items in the box between the printers and swap the filament I’d be grateful, thanks so much.
disregard, I was able to go in and clean up my mess.
Thanks, Christopher for bringing this up! I had a long print the other day and I wasn’t sure what to do as well. (In hindsight, probably should have posted here in Discourse).
I’ll try to keep my prints to a day or less in the future and block it out on skedda. Or send a heads up to this space if I need to print something longer than a day!
One idea is that the 3D printer users might aim to regularly put their phone number into their skedda reservation along with their name so that it would be easy to get in touch with each other when they expect a longer print.
Found that this post exists already, going to keep it in thread. Has the policy changed? I have a fairly long print (v confident it works on PrusaXL, just ran one with similar parts) that will run 1 day + 18hrs…
The current policy is that you may only schedule 24 hours per week on the XL so that as many people as possible have a chance to use it. You can email 3dprinters@asmbly.org for specific details.
The latest booking policy for the XL can be found here: Prusa XL - Asmbly Wiki
And for all spaces (including 3D), here: Access Policies - Asmbly Wiki
