Problem with Tray 1 on sawgrass printer
An FYI on the sublimation printer. I had problems with Tray 1 reporting a misfeed. I was unable to find the wayward scrap of paper and have reported the problem. I was able to print using the bypass tray so the printer does work you just need to use the bypass tray. Hope this helps all you sublimators.
