Hi all- I did two prints last weekend with the Polyprinter (thanks for getting the laptop working, Aneel and Eric!) and ran into another issue- the layers didn’t completely line up like they used to. I tried again with my own brand-new filament, no change. Is it possible that one of the belts on the Polyprinter is worn? Or is this more likely something else?
Interesting, yah not sure could be a bearing or belt maybe. I will do a test print in the next day or so.
if you want to scroll through the manual and see if there is any routine maintenance that we can do to eliminate possible variables that would be helpful.
Sorry, didn’t officially reply. See my post above.
Thanks! I’ll remember that! The tool is in the print lab?
I tried making a print and it is still warped- this is the bottom of an electronics enclosure, it should be completely filled in.
k Let me try tightening the other belt a bit
I was adjusting the wrong one on the X. I thinks it good now
. give it a try again
