Planer cleaned and should run better
I cleaned out the inside of the planer. There was quite a buildup that was preventing good airflow. That contributed to the continuous clogging. Better now. Flipped and replaced some carbide teeth. I don’t think that it had been serviced in a long while.
Thank you!
So, last I saw, the hand router table was on a 4" port to the Delta, with no blast gate. So, the collection would be split between two tools
Was this intentional?
I have noticed that as well, but don’t understand why that is. The router has been set up that way for quite some time.
