I used Pearl today and found that mid-session there was a weird glitch that misaligned my cut. This happened multiple times with different files, so i think it’s an issue with the machine? I put in a report, but if someone has experienced this before and knows a fix please let me know.
PS: tried adding an image for reference but it says I’m not allowed … is that a permissions issue or does asmbly’s discourse not allow it?
Im not sure what you mean by “middle section” if is the area coming from top to bottom, around the 9" mark or so is the focus stick on the left. You have to remove it as the gantry often runs into it just enough to get misaligned. Should have been covered in the class as it is a known operation issue. If is something else disregard the above.
