Pearl laser cutter
Hey I wanted to see if anyone had a solution to pearl laser, it seems like it is recognizing the bed as a different size so it wont run prints properly, not sure if others were having this problem or if anyone has a solution.
Is it possibly from the bed not getting set back after the rotary was used? I forget exactly how it’s labeled, but one of the extra tabs in the ULS print settings should show some options about rotary and bed size.
I was having some trouble finding the correct settings to reset the bed size to the right portions. If seemed like even after turning off the rotary setting the bed size still wasnt reading correctly.
