Need help to get going with CNC
Hello every one,
I was wondering if someone with more experience would have 10-15 mins to look at my toolpath files and tell me what I am doing wrong or if there is any issue with my set up, etc..
Here is more context:
I am new to CNC carving - working on a topographic 3D mapping piece. I had my first set up according to the one pager hand out James has created. Everything looked great. When the process started, the bit, instead of starting at the time and carving its way down, carved right into my stock and then it got stuck there. After rescuing my bit, I checked the zero Z surface and it was set right - on top of the stock. I double checked the toolpaths and I cannot see any issues. I am not sure what the problem is.
Thanks,
Mosen
Post your VCarve file here, and / or GCODE file here. DM me @bwatt if it is too big.
