I have a fairly new Prusa Core One+ that has started having some issues.
I’m pretty sure the issue is caused by a nozzle clog, but it could also be something wrong with the extruder gear.
What happens is that my printer will start failing to extrude any material, and I’ll hear a clicking sound as the extruder gear starts to grind into the filament.
I performed a cold pull, but this did not fix the issue.
I am hoping that I can get this running without having to order any replacement parts, as I need to use this printer for some time sensitive projects.
If anyone here is experienced in troubleshooting and fixing prusa printers, I’d really appreciate a hand.
then its not the PLA, maybe the PHA temp was too high. Also the PHA must be kept dry - if its not in a sealed container with a desiccant, then stick it in an oven before use to remove moisture
