MakerBot Method X open for use!
Asmbly recently received a donation of a MakerBot Method X printer. It is now available for reservations on Skedda!
This printer is interesting because it has a heated chamber, which can be used for printing “engineering” filaments more reliably and annealing them afterwards. @ewei found that CF-Nylon parts printed for Weaponized Plastic Robots were significantly stronger after annealing.
We have a basic Wiki page here: Method X - Asmbly Wiki We don’t have a lot of experience with this printer yet, so please feel free to add to that if you use this printer.
Caveats: Ultimaker likes to operate a closed ecosystem, this means:
  1. You will likely need to use Cura as the slicer for this printer
  2. If you are printing with non-MakerBot branded filament, you’ll probably need to use the Labs nozzle to get the results you want
  3. The filament spools that fit into the filament bays are an unusual size, and we haven’t built up a stock of empty spools to respool onto, so you’ll probably need to feed non-MakerBot branded filament through the external feed path.
Using this printer requires that you’ve taken the Intro to Filament 3D Printing Class, but this printer is fairly different from the Prusa and BambuLabs printers that we cover in this class, so be prepared to learn as you go!
