I’m looking for a source of connector bolts & nuts in quantity. Preferably 1/4" or larger. My current plan is for them to be inset and spanning 1/2", but that could be increased to 5/8". I can find them in the expensive small quantity packs at the big box stores, but I’m looking to buy 100 pairs or so.
The use case is to bolt bookcase units together as well as other cabinets. Not to assemble them using connector bolts, but to bolt the assembled bookcases and assembled cabinets together in the rooms they are going in.
I bought some several years ago from a local supplier on Braker and the quality was unacceptable.
My backup plan is to buy weld nuts and button head screws. Not exactly what I want, but they will work.
Thanks, I couldn’t remember the name. The shortest ones, which were the size I needed for a project were defective, it was impossible to screw the bolt all the way into the nut which left a huge gap. They looked like the correct part, but what they delivered wasn’t going to work.
Below are some choices. If you decide to go with the dowel nut, make sure you order the 5/8 not the 1/4. Another alternative you can look at chicago screws which they come in different grades and metals.
Cool! I have never seen the term “KD Nut”. 18mm is longer than what I have been thinking, but I should be able to make it work. Let me look up the matching bolt and get them on order.
I just ordered 20 pairs of nuts & bolts. The shipping was more expensive than the parts. This may solve an issue that has been bugging me. Now I just need to get through the CNC Router class so I can start building. I appreciate the help!
American Bolt Company 5214 Burleson Rd. Austin, Tx. (South Austin) They have all the bolts and all the fasteners and you get a discount the more you buy. Hope this is helpful.
