Light burn, shapes cutting out of order
I was running a bunch of test pieces today on Dorian and some of the cuts were being done in a seemingly random order and not following the order of the layer stack. When some are thru cuts and others aren’t this is a problem
Has anyone else experienced this and have any suggestions other than manually cutting each layer at a time?
You may need to check the cut optimization settings, are you still having the problem?
Haven’t been back to try it but looked at my settings and it was definitely whacked. That should fix it
Ty!
