Laser welder
Somehow in the past two days the setup for the MOPA laser got thrown onto a cart and removed from the table it was set up on.
Today was the main time I had to test that this machine was working functionally. I don’t have the time (or the pain-free movement ability) to set everything back up today.
I’m not sure why this happened, there isn’t somewhere to move that machine, and I will not have time to set things back up for some time now. Please avoid disassembling workstations that are in approved locations…
This was from us getting the laser welder class dialed in. We should have that finished up in a couple days. Then gonna work on its enclosure. My bad for not giving a heads up
That makes sense- probably should’ve checked with yall as well when I was confused.
Thank you!
What is the next project that needs to be worked on? I am going to head up this afternoon (5/5)
I am trying to dial in the aluminum setup on the laser welder, but we have some planning work to do on the fiber laser.
also you can get the MOPA enclosure going.
