Is anyone able to help me figure out why the laser cutter is leaving gaps in my cuts? This is a file I downloaded and it doesn’t show any gaps. Im using Dorian.
Thanks in advance, Heather
Hi Heather! Just for your information I used the Dorian Machine in the time slot before you and didn’t see any gaps in what little I did. See photo below of one of my tests. Note: I did reboot the PC after I was done, because I’ve been told it should reset any of my settings and make the machine pure, that is, without any custom settings.
I’m sure it’s something in the design and not a fault of the laser. I just can’t figure it out.
I dont know ifthis is helpful, but this is the design. I dont see anywhere that there are these gaps.
It looks like the tab setting in Lightburn. Look at your settings carefully, I believe it’s in the bottom half of the modal window.
Nice design!
I’ve had the same issue!! Was it the tab settings Heather?
Thanks, I wish i could take credit for it, but i bought it on etsy.
I haven’t been back yet to check it out. I’ll update when I go back in.
