Laguna Swift Red Tagged
The Swift CNC is Red Tagged.
The red tag has been removed on Laguna Swift.
The spindle had been burned out due to the spindle rubbing on a member’s work piece. The bit had insufficient cutting depth for the depth of the work piece.
Please be sure to verify the cutting depth of your bit. The collet nut or spindle should never be in contact with the work piece. If you smell a smokey or burning smell please pause your work and investigate. Replacing the spindle is a costly maintenance item.
Thank you.
