In case you are planning on working on the Large CNC…
I was unable to use the 5x10 Laguna CNC tonight. (problem report also submitted)
After power on when I selected “Home All” the machine homed, then got in a state where it would no longer move the gantry in order to set a new origin and set a zero for z.
As a workaround I tried to not zero at power up which allowed me to move the gantry, however the x axis hit a software limit around +12iin and y axis around +8ft. Setting zero also did not work in this state.
I tried the ‘MENU+0’ workaround suggested in another thread but i didn’t get the machine in the correct state per that message either.
The image with X Home, Y Home, Z Home, A Home is from the case where I homed right after power on and the Gantry was no longer movable.
The Other was when I didn’t home and was able to move the gantry around.
