I came in this morning to use the jointer & planner. The jointer is disassembled—it appears that someone started to replace the cutters but did not complete the job. I filed a red tag notice but I also wanted to alert other members who may want to use it so they can determine if it’s fixed before they arrive.
Thank you! Same here - arrived with my boards to square up and found the jointer down.
Thanks again for starting the thread!
Jointer is back up and running. All of the teeth have been rotated / replaced, so it should be good to go.
Thank you Charlie for the update.
Thank you Charlie!
@BillM fixed it. I’m just reporting it.
@BillM Thank you for finishing the maintenance on the jointer. It was sorely overdue ![]()
